How to Draw a 3D TV
How to Draw a 3D TV
Unread postby evortarve » Fri Jan 20, 2012 1:15 am
Attracting a TV requires some basic shapes just like rectangles, which is the easy part. Turning it straight into 3D, takes practice. The artist needs to take into consideration various degrees regarding values and shadows so that you can create shading. To turn level surfaces into 3D is usually a matter of developing a gradual change within value from light-weight to dark. This gradual adjust will add curves towards TV and provide effect of depth and so, a 3D TELEVISION SET.
1. Draw a rectangular shape to represent the length of the TV.
2. Create another rectangle from the first rectangle to be able to represent the monitor.
3. Draw two lines decreasing from the middle of the first rectangular shape to represent the particular height of TELLY.
4. Draw a rectangular shape and center it underneath the two lines in order to represent the Video's stand.
5. Add gradual shading towards rectangle of the television and stand for you to transition from lighting to dark. Do not add shading towards screen. Gradual shading will build a curved surface and provides a 3D influence. Create the darkest price of shading with the edges.
evortarve
Return to General - Questions, Ideas & Opinions
cron
