How to Use ELM327 OBD-II OBD2 CAN USB Interface Diagnostic T
Unread postby OBD Connector » Sat Aug 20, 2011 5:07 am
Tips on how to Use ELM327 OBD-II OBD2 CAN USB Interface Diagnostic Tool
ELM327 OBD-II OBD2 CAN USB Interface Diagnostic Tool is very uncomplicated to make use of. Just turn your laptop or computer into a vehicle diagnostic system. This interface with software included is all you'll need. Works for most of cars following 1996. It can read and clear all diagnostic trouble codes. Display all the live information of your automobile.
ELM 327 Directions:
There are several software for running ELM327, now we are talking about software program EasyobdII 2.two version.
1. Very first, Connect your laptop with your auto and turn the important on or turn the engine to be running.
two. The hardware will be detected and automatically installed, ready to make use of. Otherwise, you need to use driver file to install it.
three. Should you use Windows Vista, only the software program EasyobdII two.two works with Vista. For rest operation system ought to not such difficulties.
four. In the first attempt, you could have predicament and see screen like the following.
There are actually five alternatives like com1, com2, ...com5.
five. At this step, you will need Go to Control Panel--> method --> Device manager -->Ports(Com&LPT) --> USB serial port(com?), to find out which com number you will need choose.
6. If the above com number is com1, Restart program EasyobdII, choose COM port as com#1 at bottom line of program, and let the program detect auto ECU.
7. The system will generate information and shows on screen.
8. Other thing to attempt: plug and unplug obd connector and make sure connection is OK; or attempt a different usb port of your laptop.
OBD Connector
Return to General - Questions, Ideas & Opinions
